![5V TO -12V Inverting Switching Regulator 5V TO -12V Inverting Switching Regulator](https://www.electronics-lab.com/wp-content/uploads/2016/06/PIC.jpg)
The DC/DC inverting switching regulators project is specifically designed to invert input voltages to negative outputs. It offer input voltage ranges from 4.5V to 6V and output -12V 100mA The MC34063A IC is heart of the project from On semiconductor. The MC33063A is a monolithic control circuit containing the primary functions required for DC-DC converters, This device consist of an internal temperature compensated reference, comparator, controlled duty cycle oscillator with an active current limit circuit, driver and high current output switch. This IC specially designed to be incorporated step-down, step-up, and voltage-inverting applications with minimum number of external components.
- Input 4.5V To 6V DC
- Output -12V 100mA
- Output Fine Adjustable By On-board Preset
- Header Connector for Output/Input Connections
- Low Standby Current
- On Board Filter To Provide Low Ripple Output
- PCB Dimensions 31.75mmX34.93MM
5V TO -12V Inverting Switching Regulator – [Link]
