![5V & 12V Regulated Power Supply 5V & 12V Regulated Power Supply](https://www.electronics-lab.com/wp-content/uploads/2015/11/Regulated_PSU_G035_11-1024x820.jpg)
This project can be used to power up TTL and CMOS based projects, it provides 5 VDC & 12 VDC outputs with an onboard mains transformer. The project is based on the industry popular 7800 series voltage regulator in TO220 packages.
- Input: 240 VAC
- Output: 5 V, 12 V @ 600 mA regulated low ripple DC voltage
- Thermal overload/short circuit protection (provided by IC feature)
- Power Battery Terminal (PBT) for easy input and output connection
- External On/Off switch connection possible
- LED indication for outputs
- Four mounting holes of 3.2 mm each
- PCB dimensions 87 mm x 49 mm
5V & 12V Regulated Power Supply – [Link]
Login
