![5V @ 2A Step Down Converter using TPS54202 5V @ 2A Step Down Converter using TPS54202](https://www.electronics-lab.com/wp-content/uploads/2017/01/SCHEMATIC-1-1024x377.jpg)
The circuit shown here is a step down converter which can convert an input voltage varying from 8V to 28V to 5V. The circuit is based on TPS54202, which is a 2A synchronous buck converter. This IC has several features such as over-voltage protection and peak current mode control.
- Input(V): 8V DC to 28V DC
- Output(V): 5V DC
- Output load: 2A
- PCB:25mmX15mm
5V @ 2A Step Down Converter using TPS54202 – [Link]
Login
