![5V Step Down DC-DC Converter 5V Step Down DC-DC Converter](https://www.electronics-lab.com/wp-content/uploads/2016/05/5V-STEP-DOWN-DC-TO-DC-CONVERTER-PIC.png)
The Tiny Step-Down DC-DC converter project provides 5V 500mA output from supply input up to 25V DC. MC34063A IC is heart of the project from on semiconductor. The MC33063A is a monolithic control circuit containing the primary functions required for DC-DC converters, This device consist of an internal temperature compensated reference, comparator, controlled duty cycle oscillator with an active current limit circuit, driver and high current output switch. This IC specially designed to be incorporated step-down, step-up, and voltage-inverting applications with minimum number of external components.
- Input 12- 25V
- Output 5V, 500mA
- Output filter for clean output
- Output Voltage Fine Adjustable 20%
- Header Connector for Output/Input Connections
- Low Standby Current
5V Step Down DC-DC Converter – [Link]
Login
