![5V Symmetrical Regulated Power Supply 5V Symmetrical Regulated Power Supply](https://www.electronics-lab.com/wp-content/uploads/2016/02/5V_Power_Supply_G003.jpg)
This Project provides Positive and Negative (Dual Output) 5 V @ 1 A Regulated Power Supply.
Specifications
- Input 7-0-7 VAC to 12-0-12 VAC or +/- 9 to 18 VDC
- Output : Dual output ± 5 V @ 1 A regulated low ripple DC voltage
- Heat-sink for regulator ICs
- Onboard bridge rectifier to convert AC to DC
- LED indication for both the outputs
- Thermal overload/short circuit protection (provided by IC feature)
- Screw terminal connector for easy input and output connection
- Filter capacitors for low ripple DC output
- Four mounting holes of 3.2 mm each
- PCB dimensions 46 mm x 60 mm
5V Symmetrical Regulated Power Supply – [Link]
Login
