![60V to 5V @ 3.5A Buck converter with USB output 60V to 5V @ 3.5A Buck converter with USB output](https://www.electronics-lab.com/wp-content/uploads/2019/11/IMG_0001.jpg)
This is a 60V to 5V – 3.5A step down DC-DC converter based on TPS54360B from Texas Instruments. Sample applications are: 12 V, 24 V and 48 V industrial, Automotive and Communications Power Systems. The TPS54360 is a 60V, 3.5A, step down regulator with an integrated high side MOSFET. The device survives load dump pulses up to 65V per ISO 7637. Current mode control provides simple external compensation and flexible component selection. A low ripple pulse skip mode reduces the no load supply current to 146 μA. Shutdown supply current is reduced to 2 μA when the enable pin is pulled low.
60V to 5V @ 3.5A Buck converter with USB output – [Link]
Login
