Epiq Solutions Develops Wideband RF Transceiver SDR Module Running Linux On Zynq SoC
Epiq Solutions, a company from the USA, has included a new member of its Sidekiq line of Software-defined radio (SDR) add-on cards called the Sidekiq Z2. Dimensions of this card are only 51 x 30 x 5mm, the size of a full-size mini-PCIe card, the Sidekiq Z2 computer-on-module is advertised as “the world’s smallest wideband RF transceiver + Linux computer in a product-ready module”. The module is most suitable for handheld RF testing and measurement, remote RF sensing, wireless security applications, and CubeSat/UAS datalinks. A carrier board is also available with this module.
Unlike previous Sidekiq cards, the Sidekiq Z2 can act as a standalone computer, running Linux on a Xilinx Zynq-7000 series Arm/FPGA SoC. Like the original Sidekiq, which is available in mini-PCIe or M.2 form factors, the Sidekiq Z2 operates at 70MHz to 6GHz. There’s also a Sidekiq X2, which uses the VITA57.1 FMC form factor, which supports 1MHz to 6GHz frequencies.
Epiq claims, the new Sidekiq Z2 can boot Linux in under two seconds, with a typical system power consumption under 2 Watts. The Zynq comes with 512MB DDR3L RAM and 32MB QSPI flash. The SoC drives USB 2.0 OTG, serial UART, JTAG, and GPIO signals to a carrier board.
The shielded AD9634 1Rx + 1Tx transceiver has a 4-band Rx pre-select filter bank and an up to 61.44 Msamples/sec sample rate. The 40MHz TCVCXO ref clock features +/- 1 PPM stability. The 3.3V, 8-gram module supports -40 to 85°C temperatures. The module also offers many U.FL antenna connectors.
The company offers a Sidekiq Z2 Evaluation Kit (EVK) that includes two Sidekiq Z2 cards pre-loaded and supported by Analog Devices’ open source IIO reference design, along with two simple carrier cards. An optional Platform Development Kit (PDK) offers enhanced support and an optimized FPGA reference design to maximize processing capability of the FPGA. Epiq Solutions also presents applications for embedded RF spectrum analysis as well as 2G/3G/4G cellular network survey.
The Sidekiq Z2 is available now at a price of $649 for 1,000+ unit orders. The Sidekiq Z2 EVK and PDK also appear to be available, with pricing undisclosed. More information may be found in the Epiq Solutions Sidekiq Z2 announcement and product page.
