![7″ 1024 x 600 IPS Display for LattePanda 7″ 1024 x 600 IPS Display for LattePanda](https://www.electronics-lab.com/wp-content/uploads/2018/11/1-900x600-1.jpg)
Add exciting new dimensions to your project with this large full-color display. All you need to do is power your LattePanda single board computer and you have a visual user interface for your project – no extra power cables required! The border of the display is insulated with black tape so that even without and enclosure there is no possibility of a short-circuit. The picture below shows a LattePanda directly powering the 7″ display.
Note: LattePanda uses a custom MIPI pinout that will not be compatible with alternative IPS displays! You can still use HDMI out. Use your display in conjunction with the capacitive touch panel (not included) to get a touch interface for your project! NOT compatible with LattePanda Alpha and Delta edition
SPECIFICATION
- 7″ IPS display
- 1024 x 600 high resolution
- Dimensions: 164.0mm x 96.0mm x 2.6mm
- Supports LattePanda
- 10cm FPC connector
DOCUMENTS
The LCD module is available for sale on www.dfrobot.com for $34.00.
Thank you for sharing this fantastic post.
