![+9V TO 60V PWM 2.3A SOLENOID VALVE DRIVER USING DRV101 +9V TO 60V PWM 2.3A SOLENOID VALVE DRIVER USING DRV101](https://www.electronics-lab.com/wp-content/uploads/2017/01/9V-TO-60V-PWM-SOLENOID-VALVE-DRIVER-M104B.jpg)
The DRV101 is a low-side power switch employing a pulse-width modulated (PWM) output. Its rugged design is optimized for driving electromechanical devices such as valves, solenoids, relays, actuators, and positioners. The DRV101 module is also ideal for driving thermal devices such as heaters and lamps. PWM operation conserves power and reduces heat rise, resulting in higher reliability. In addition, adjustable PWM potentiometer allows fine control of the power delivered to the load. Time from dc output to PWM output is externally adjustable. The DRV101 can be set to provide a strong initial closure, automatically switching to a soft hold mode for power savings. Duty cycle can be controlled by a potentiometer, analog voltage, or digital-to-analog converter for versatility. A flag output LED D2 indicates thermal shutdown and over/under current limit. A wide supply range allows use with a variety of actuators.
+9V TO 60V PWM 2.3A SOLENOID VALVE DRIVER USING DRV101 – [Link]
