AAEON’s Intel Core-Powered PICO-KBU4 will Help Your Applications Take Flight
(Taipei, Taiwan – June 19, 2018) – AAEON, a leading developer of embedded controllers, announces the launch of the PICO-KBU4, a rugged and expandable compact SBC with the capacity to revolutionize the field of robotics and open up the drone market for x86 embedded controllers.
Fitted with a 7th Generation Intel® Core™ i processor (formerly Kaby Lake) and featuring up to 16GB DDR4 SODIMM memory, the PICO-KBU4 has the computing power to handle applications previously only possible with much larger motherboards. Its market-leading pair of GbE LAN ports enable the use of two HD cameras, and with its GPIO, two COM ports, two USB3.0 ports, and two USB2.0 pin headers, it can connect to and control a range of sensors.
The PICO-KBU4’s compact, lightweight specifications are an obvious advantage with drones, robotics, and even conventional, factory machine vision systems. The board can be used in spaces once considered too small to house a powerful embedded controller, and its low power-consumption figures are an additional benefit with battery-reliant drones.
A 0oC~60oC operating temperature range, HDMI and LVDS ports, SATA slot, and M.2 B and E keys for extra storage and WiFi / Bluetooth connectivity make this an extremely flexible SBC, and customers can expand the already impressive IO interface by adding a custom-made daughter board via an optional board-to-board interface.
“This board’s combination of high-performance computing with a small form factor mean it will be the future of not only factory automation systems, but also robotics, and advanced drones,” said Jones Huang, AAEON embedded computing division product manager. “Any drone equipped with a PICO-KBU4 will be able to stay in the air for a long time, and that will make it a powerful surveillance tool or air quality monitor.”
