![AC Motor Speed Controller for Modern Appliances Using LS7311 AC Motor Speed Controller for Modern Appliances Using LS7311](https://www.electronics-lab.com/wp-content/uploads/2017/01/AC-MOTOR-CONTROLLER-USING-LS7311-1.jpg)
The project specifically designed for motor speed control application in appliances such as blenders, etc. Tact switches provided for selecting/indicating from 1 to 10 power levels ( Speed Levels). The project is ideal for universal and shaded-pole motor speed control for modern appliances design. Eliminates awkward mechanical switch assemblies and multi-taped motor winding.
- 10 Tact Switch for Speed Selection
- 10 LEDS for speed indication
- On Board Stop and Start Switches ( Start Switch Latch Operation)
- Momentary Run Switch
- Supply 230V ( 110V Possible Refer Data sheet for components Change)
- 300W Load
- On Board snubber for Inductive Load
- No Separate DC power supply required
AC Motor Speed Controller for Modern Appliances Using LS7311 – [Link]
Login
