AC Solid state Relay for Inductive Load offers simple On/Off type Switch Control with TTL compatible input signal.
- Input signal : 2 ~ 5 VDC, TTL compatible
- Output : up to 500 W
- Mains supply input 230 VAC or 110 VAC
- Optically isolated Triac based design
- Power Battery Terminal (PBT) and Terminal pins for easy input / output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 35 mm x 72 mm
AC Solid state Relay for Inductive Load – [Link]
Login
