![Accura 3 GHz to 5 GHz Ultra-Wide Band (UWB) SMD Chip Antenna Accura 3 GHz to 5 GHz Ultra-Wide Band (UWB) SMD Chip Antenna](https://www.electronics-lab.com/wp-content/uploads/2021/08/De_3hNsXcAAn77k-e1628349502490.jpg)
Taoglas’ Accura UWC.40 is a tiny indoor centimeter-level positioning antenna for European and United States applications
Taoglas’ Accura UWC.40 is a tiny indoor centimeter-level positioning antenna with high efficiencies across the pulsed UWB communications bands. With dimensions of only 6 mm x 7 mm x 3 mm, the UWC.40 is a very small antenna that is reliable and powerful, with more than 80% efficiencies across most of the UWB bandwidth.
Applications
- Automotive sensors
- Smart airbags
- Precision surveying
- Smart home and entertainment systems
- Centimeter level positioning
Specifications
- SMD Chip UWB Antenna
- For European and USA UWB Applications
- In Channels 1-4
- Frequency: 3.1-4.75GHz
- Dimensions: 6*7*3mm
- RoHS Compliant
more information: https://www.taoglas.com/product/indoor-centimeter-level-positioning-antenna/
Login
