![Adafruit unveils QT Py ESP32-C3 development board with Wi-Fi and Bluetooth support Adafruit unveils QT Py ESP32-C3 development board with Wi-Fi and Bluetooth support](https://www.electronics-lab.com/wp-content/uploads/2022/06/Adafruit-QT-Py-ESP32.jpg)
Adafruit has been famous for developing miniature development boards for IoT applications, such as the Adafruit QT Py dev boards powered by RP2040 and SAMD21. Adafruit, yet again, comes with another QT Py with ESP32-C3 module that supports Wi-Fi and Bluetooth Low Energy wireless connectivity. As a RISC-V microcontroller onboard, the hardware gives a lot of flexibility to new developers to explore the vast capabilities of a RISC-V process.
Recommended reading: Adafruit QT Py– SAMD21 Dev Board with STEMMA QT
As mentioned earlier, the ESP32-C3 module is based on the RISC-V open-standard instruction set architecture with a single-core 32-bit RISC-V processor core, clocked at a frequency of up to 160MHz. The key highlight of the microcontroller device is the wireless connectivity support for a complete Wi-Fi subsystem that complies with IEEE 802.11b/g/n protocol and supports Station mode, SoftAP mode, SoftAP and Station mode, and promiscuous mode. On the Bluetooth side, the Bluetooth LE subsystem supports features of Bluetooth 5 and Bluetooth mesh.
Recommended reading: Adafruit QT Py RP2040 Dev Board features large storage memory
Specifications of QT Py ESP32-C3 dev board
- SoC: Espressif ESP32-C3FN4 ultra-low-power, highly integrated MCU-based microcontroller
- Memory: 400kB of SRAM
- Storage: 4MB of flash storage
- Wireless connectivity: IEEE802.11b/g/n Wi-Fi and Bluetooth LE
- LEDs: Built-in RGB NeoPixel LED
- GPIOs: 13x GPIOs
- 11 on breakout pads
- 5x 12-bit analogue inputs
- PWM outputs on any pins
- I2C port on breakout pads shared with STEMMA QT plug-n-play connector
- Hardware UART, which is also a hardware serial debug port
- Hardware SPI
- Hardware I2S on all pins
- Serial communication: I2C, UART, SPI
- Software support: Arduino IDE and MicroPython
- Weight: 2.1 grams
Interestingly, even the small form factor development board comes with a hardware I2C port on the breakout pads that can be used as a STEMMA QT plug-n-play connector. Leveraging the standardized interface, developers can seamlessly connect various modules and sensors that add functionality to the development board. Some of the widely used sensors are air quality sensor, capacitive touch sensor, proximity, light, RGB and gesture sensor, time-of-flight distance ranging sensor, and many more. A detailed view of STEMMA QT products can be found on the Adafruit website.
If you are interested in purchasing the Adafruit QT Py ESP32-C3 dev board, head to the product page, where it is priced at $9.95.
