![Adjustable constant current source Adjustable constant current source](https://www.electronics-lab.com/wp-content/uploads/2017/05/33749839094_34f696c530_z.jpg)
Dilshan Jayakody has published a new build:
The current source introduced in this article is capable to handle current up to 6A with maximum input voltage of 50V. This is an operational amplifier based adjustable current source and it uses LM358 in a general voltage follower configuration. To handle large currents we use four 0.1Ω 20W resistors as “load resistor”, and those load resistors are drive through pair of 55N06 N-channel MOSFET transistors.
The power supply unit of this project is build around 9V x 2 (2A) step-down transformer and it is design to get regulated 12V DC voltage. In our design this 12V power source is used to drive LM358 Op-Amp and 12V cooling fan.
Adjustable constant current source – [Link]
Login
