![All-in-One Multimeter LCR-Reader-MPA All-in-One Multimeter LCR-Reader-MPA](https://www.electronics-lab.com/wp-content/uploads/2020/11/71quaWpSJJL._AC_SL1500_.jpg)
LCR-Reader from Siborg Systems Inc. is an easy-to-use multimeter with automatic measurements. It offers a record high accuracy and unrivaled functionality. The device has reached the finals for Plant Engineering’s Product of the Year 2020 for Maintenance Tools and Equipment. Voting opens on November 12th and the winners will be announced in January 2021.
Plant Engineering is an online and print magazine about products for production and manufacturing. Subscribers can vote on the LCR-Reader-MPA page by clicking the trophy on the right hand.
The multimeter device offers 0.1% basic accuracy and virtually does not require set-up between measurements. When a component is between the tweezer’s gold-plated tips, LCR-Reader-MPA will automatically determine the type of component and best test frequency to use for high accuracy measurements. Measurements are done with a 0.1% basic accuracy and are automatically available on the display, including the main and secondary impedance values, test frequency, and signal level used.
LCR-Reader-MPA is the ultimate testing and troubleshooting tool for PCBs and component sorting. The main features of the device are the measurement of LCR/ESR with up to 100 kHz test frequency, AC/DC Voltage/Current measurements, oscilloscope mode, LED/Diode testing and Super Cap testing.
Features:
- 0.1% basic accuracy
- Fully automatic and manual LCR/ESR. LED/Diode measurements
- Automatic and manual test frequencies 100, 120 Hz, 1, 10, 20, 30, 40, 50, 60, 75 and 100 kHz
- LED/Diode testing
- Easy Open/Short calibration and offset removal
- Oscilloscope mode
- Large and Super Large capacitance testing
- Three test signal levels
- Signal Generator
- 1.3 oz. weight
- Li-Ion battery with micro-USB charging
Recently the LCR-Reader-MPA Bluetooth was released. This model can connect with Android and Windows devices to send and receive measurement data, which can be later exported to a spreadsheet. When connected to the LCR-MPA-BT Data Logger Program, users are able to set custom measurement parameters which components are required to meet. The program automatically displays whether the component passes or fails and marks them red or green in the spreadsheet. The ability to record measurement values in real-time is exceptionally helpful for quality control. The automatic Pass/Fail feature is best for sorting large and varied amounts of components.
Voting for Plant Engineering’s Product of the Year closes February 5th, 2021. Vote now for LCR-Reader-MPA.
Siborg offers a wide range of test equipment and accessories in its online LCR-Reader Store and through its Amazon sales channels in North America and Europe.
