AMPCOM 9-Port 2.5GbE Switch with Web Management, 10G SFP+ uplink, and QoS for Office and Surveillance Networks
1.026
The AMPCOM 2.5GbE Managed Switch is a high-performance 9-port Ethernet switch featuring 8 RJ45 ports (100/1000/2500 Mbps) and a 10G SFP+ uplink port, designed for seamless network connectivity and management.
9-port Ethernet switch build
Various IEEE standards are supported by the switch, and QoS prioritization, VLAN capabilities, port aggregation, and 6KV lightning protection are provided, all while maintaining low power consumption as well as featuring a fanless design for ensuring quiet operation, making it a great fit for office settings. It is well-suited for security systems, enterprise networks, educational institutions, hotels, and small to medium-sized businesses. Advanced Layer 2 functions like VLAN configuration, link aggregation, port mirroring, and QoS are included, along with a user-friendly web-based management interface. Certified for safety and environmental standards, it operates within a wide temperature range. Its robust build quality suits multimedia transmission, private networks, and real-time monitoring systems.
9-port Ethernet switch web login
Previously, we have written about the iKOOLCORE R2 Max, a mini-server powered by the Alder Lake-N i3-N305 8-core having a 10Gbps port. We have also covered the AAEON FWS-8600, a network security solution, based on 2nd Generation Intel Xeon Scalable processor. We have previously learned about Solidrun ClearFog GT 8K, which has four GbE ports and a 10GbE SFP+ port, almost similar to AMPCOM 2.5GbE Switch. Feel free to check those out, if you are interested in this topic.
If you don’t need as many ports, there are other affordable options like the OPTFOCUS OFS-MX1F2GT4 on AliExpress, which offers four 2.5GbE ports and two 10GbE SFP+ cages for $37.69 during the AliExpress 11.11 event or $45.14 otherwise. In contrast, most 10GbE switches on Amazon are priced between $200 and $400, with the cheapest models starting at around $120.
9-port Ethernet switch indicators
AMPCOM 9-Port 2.5Gb Ethernet Switch Specifications:
  • Ports:
    • 8 x 100/1000/2500M RJ45
    • 1 x 10G SFP+ uplink port
  • Ethernet Standards: IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3ae, IEEE 802.3x
  • Network Protocols: IEEE 802.3x Flow Control, Spanning Tree Protocol (STP), IGMP Snooping, etc.
  • Network Medium: 10Base-T, 100Base-TX, 1000Base-TX, SFP Medium
  • VLAN Support: IEEE 802.1Q VLAN tagging, supports up to 31 active VLANs
  • Forwarding Mode: Store and Forward
  • Industry Standard: EN61000-4-2 (ESD), EN61000-4-5 (Surge)
  • Link Aggregation: Static Group, Up to 2 groups, Max. 4 members per group
  • Flow Control: Full duplex (IEEE 802.3x), Half duplex (Backpressure)
  • QoS: Supports up to 8 queues per port, traffic classification-based, strict priority and WRR
  • Jumbo Frames: Up to 16,356 bytes
  • Surge Protection:
    • 6KV Common mode
    • 2KV Differential mode
    • 8KV Air ESD
    • 6KV Contact ESD
  • Misc:
    • 10GbE LEDs for port 9
      • Green: 10Gbps Link
      • Off: Link off
      • Flashing: Data transmitting
    • 2.5GbE LEDs for ports 1-8
      • Green On: 2.5Gbps Link
      • Yellow On: 10/100/1000Mbps Link
      • Off: Link off
    • Reset button:  6 seconds Long press for factory reset
    • System LED
  • Power Consumption: <2W standby power, 11.29W max
  • Power Input: DC 12V 1A (Adapter), AC 100-240V (Input)
  • Physical Size: 190 x 100 x 28mm
  • Weight: 0.49kg (unit), 0.71kg (package)
  • Operating Temperature: -10°C to 50°C
  • Storage Temperature: -40°C to 70°C
  • Certification: CE, FCC, RoHS
9-port Ethernet switch port aggregation
AAEON has previously introduced the VPC-5640S, a Multi-PoE having four PoE LAN ports running at 2.5GbE speed (IEEE802.3 at/af), alongside an additional standard RJ-45 for Intel Ethernet Controller I226-LM. Compared to this product, the AMPCOM 2.5GbE Managed Switch has far better features, and it is available on the product page for $70.48.
9-port Ethernet switch dimension
The AMPCOM 2.5GbE Managed Switch is also available on Aliexpress at $47.51 with a free shipping charge, which is less costly than the official website.
About Sayantan Nandy
view all posts by sayantan
