The TMF8805 is a time-of-flight (TOF) sensor in a single modular package with associated VCSEL
The TMF8805 is a time-of-flight (TOF) sensor in a single modular package with associated VCSEL. The TOF device is based on SPAD, TDC, and histogram technology. The device achieves a 2500 mm detection range.
Key features
- Direct ToF technology with high sensitivity SPAD detection
- 20…2500 mm distance sensing at 30 Hz
- On-chip histogram processing
- Industry’s smallest modular OLGA 2.2 x 3.6 x 1.0 mm package
Additional features
- Fast Time-to-Digital Converter (TDC) architecture
- Sub-nanosecond light pulse
- 940nm VCSEL Class 1 Eye Safety
- High-performance on-chip sunlight rejection filter and algorithm
Additional Benefits
- Delivers high SNR, wide dynamic range, and no multi-path reflections
- Enables dark and sunlight environment distance measurement within ±5%
- Provides best-in-class resolution ranging mode detection sensing
- Enables accurate distance measurements
- Provides high accuracy, greater distance between cover glass, dynamic cover glass calibration, dirt or smudge removal and crosstalk compensation
- Eye-safety circuitry stops VCSEL driver if VCSEL fault occurs
- Optical filters with algorithm support enable high ambient light resilience
- Reduce board space requirements, enables low-profile system designs in restricted space Industrial Designs
Internal Diagram
more information: https://ams.com/tmf8805
Login
