![Arduino PICO, The Tiny Arduino-Compatible Board Arduino PICO, The Tiny Arduino-Compatible Board](https://www.electronics-lab.com/wp-content/uploads/2017/07/pico-small.png)
MellBell, the Canadian-based hardware and electronics company, has launched their first product: Arduino PICO!
At first, the company says that Arduino PICO is the smallest Arduino compatible board ever, since it is 0.6″ x 0.6″ inch sized (~15mm squared). This tiny fully-fledged arduino-compatible board has a Leonardo-compatible 16MHz ATMEGA32U4 chip and a micro-USB port. The main cause of building PICO was to have a really small brain to use in many application with worrying about size or allocated space.
PICO’s Technical Specifications
The 16MHz ATMEGA32U4 integrates 2.5KB SRAM and 32KB flash, 4KB of which the bootloader uses. The 1.1-gram PICO has 8x digital I/O pins, 3x analog inputs, a PWM channel, and a reset button. In addition, the board has a 7-12V power with 5V operating voltage, where each I/O pin uses 40mA. It is worth to mention that PICO is competing with 12 x 12mm, $18 µduino, which similarly offers an Arduino Leonardo compatible ATMEGA32U4 MCU and which is smaller in size.
Moreover, MellBell provides an aluminum version that comes with the same ATMEGA32u4 core processor. With an Aluminum not regular fiber-glass, this makes PICO more reliable for overheated applications and environments.
Arduino PICO is now live on a Kickstarter campaign that two days ago had achieved its goal! Fortunately, there is still a chance until 17 Aug 2017 to pre-order one of PICO’s packages. You can get your early bird PICO for CA$18 ($14) and Aluminum edition for CA$32($25). Also, there is a special edition that includes 2× Aluminium PICO, four colored PICOs, 2× PICO joystick shield, micro drone kit, PICO solar station, 2× dual PICO board, 2× micro li-ion battery, PICO starter kit, 2× MiniMega board and finally a special “THANK YOU” video for CA$ 960 ($765).
