![Arduino Unveils Opta Digital, Analog Expansion Modules for Bigger PLC Projects Arduino Unveils Opta Digital, Analog Expansion Modules for Bigger PLC Projects](https://www.electronics-lab.com/wp-content/uploads/2024/06/1600x1600_grobo.jpg)
Arduino has announced two new entries in its Opta programmable logic controller (PLC) family, designed for those projects that are a little too complex for a single controller: the Opta Digital and Opta Analog Expansion Modules. These new modules offer additional pins and true analog outputs for the analog variant, enhancing the flexibility of any Opta PLC.
“Enhance your Arduino Opta’s real-time control, monitor, and predictive maintenance applications thanks to the Arduino Pro Opta Expansions,” the Arduino team writes of its latest launch. “Quickly put them to work, managing the new I/Os [Inputs/Outputs] from the Opta base unit seamlessly, taking advantage of the open and widely known Arduino ecosystem or PLC IDE IEC 61131-3 programming environment.”
Arduino launched the Opta micro PLC family in November 2022 as it looked to branch out into the industrial programmable logic controller market — complete with a new development environment with support for IEC 61131-3-standard PLC languages, including ladder logic and function block diagrams. Earlier this month, the company launched the PLC Starter Kit, which offers Opta WiFi along with Simulat8 and DIN Celsius add-ons and a 20-hour course to introduce PLCs in general and the Opta and its development environment specifically.
The new expansion modules target applications where the base Opta PLCs lack enough connectivity and deliver a cheaper and more easily managed alternative to simply adding additional PLCs into the mix. Mimicking the form factor of the Optas themselves, the expansion modules connect at the side and deliver either additional digital or analog connectivity — all managed from the base Opta using a simple library. Up to five modules can be connected to a single Opta, Arduino has confirmed, connecting side-by-side through their expansion ports.
![Digital Expansion Module and Analog Expansion Module](https://www.electronics-lab.com/wp-content/uploads/2024/06/Digital-Expansion-Module-and-Analog-Expansion-Module.jpg)
The Arduino Opta Digital Expansion Modules come in two varieties: the D1608E offers 16 programmable inputs, which can be used as 0-24V digital or 0-10V analog inputs, and eight electromechanical relays supporting 240V AC at up to 6A; the D1608S has the same 16 voltage inputs but swaps the electromechanical relays for solid-state versions supporting 24V DC at up to 2A. The Arduino Opta Analog Expansion Module, code A0602, meanwhile, adds six analog inputs that can be configured to read voltages from 0-10V, current up to 20mA, and two of which can read temperatures from optional RTD PT100 sensors, four digital outputs with pulse-width modulation (PWM) support, and two true analog outputs supporting 0-10V or up to 20mA programmable output — a feature missing from the unexpanded Opta PLCs.
