![Arduino Weather Station with DHT11 and BMP180 Arduino Weather Station with DHT11 and BMP180](https://www.electronics-lab.com/wp-content/uploads/2017/10/Screenshot_2017-10-22-12-15-21-1-1024x576.png)
In the previous tutorial I showed you how to build a weather station using only the DHT11 sensor and I said the readings from this sensor is fairly accurate. In this tutorial, I will be using the DHT11 to measure only the humidity and BMP180 to measure pressure and temperature. That’s because its readings are more accurate than the DHT11 temperature readings.
Arduino Weather Station with DHT11 and BMP180 – [Link]
Login
