ASUS IoT EBS-P300 Fanless Lightweight Box PC with 2.5GbE & 1GbE LAN port
1.110
The ASUS IoT EBS-P300 is a compact, lightweight embedded computer designed for industrial applications. It features an Intel Celeron J6412 processor and is optimized for use in harsh environments, offering reliable performance in temperatures ranging from -20°C to 60°C.
The EBS-P300 supports up to 8GB of LPDDR4x-3733 RAM, providing ample capacity for running multiple applications. It includes an M.2 2242 B-Key slot that accommodates either eMMC storage up to 128GB or SATA storage, as well as an M.2 2230 E-Key slot for Wi-Fi or Bluetooth devices.
The EBS-P300 is a highly adaptable industrial device, offering versatile connectivity options that include one 2.5GbE Ethernet port, one 1GbE Ethernet port, two USB 3.2 ports, and two COM ports (RS-232/422/485). For display, it provides two HDMI ports—one HDMI 2.0 and one HDMI 1.4, supporting a range of output configurations.
This fanless system is designed to endure tough industrial environments with a compact form factor of 137mm x 81mm x 40mm. It can function efficiently in temperatures from -20°C to 60°C and humidity levels between 10-95% at 40°C. The durable design also allows for DIN-rail or wall mounting, making it an ideal choice for industrial applications requiring reliable and robust performance in harsh conditions.
The device incorporates TPM 2.0 (Infineon SLB 96xx) for enhanced security, ensuring the protection of sensitive data and applications. It supports a wide range of operating systems, including Windows 10 64-bit, Windows IoT Enterprise, Ubuntu, RedHat Enterprise, Fedora Workstation, and OpenSUSE. Additionally, the ASUS IoT Suite offers extended functionality with tools for hardware monitoring, power scheduling, fan control, and a watchdog timer, enhancing operational efficiency and reliability in industrial environments.
Specifications listed for the Asus EBS-P300 include:
  • Memory:
    • Up to 8 GB LPDDR4x-3733 (one SODIMM slot)
  • Display/Audio:
    • 1x HDMI 2.0 port
    • 1x HDMI 1.4 port
  • Expansion:
    • 1x M.2 2230 E-Key for Wi-Fi/BT device
    • 1x M.2 2242 B-Key supports SATA storage
  • Connectivity:
    • 1x Gigabit Ethernet port by Intel I226-IT
    • 1x Gigabit Ethernet port by Intel I210-IT
  • I/O Interfaces:
    • 2x COM: RS-232/422/485 port
  • USB:
    • 2x USB 3.2 ports
  • Other Features:
    • TPM 2.0
  • Operating Temperature:
    • -20° to 60°C
  • Power:
    • 12 – 24V DC
  • Mechanical:
    • 137 x 81 x 40mm
    • DIN-Rail
    • Wall-mount
The EBS-P300 is available for $413.00 on the ASUS online store.
