![AT89C2051 Development Stick AT89C2051 Development Stick](https://www.electronics-lab.com/wp-content/uploads/2015/09/AT89C2051_DEV_STICK_PIC1.jpg)
89C2051 Development Stick kit offers an easy way of interfacing 89C2051 compatible MCU’s.
- Slim design with plug in type approach
- Voltage regulator on board for stable and regulated supply to the MCU
- RESET switch for resetting the MCU
- 0592 MHz Crystal
- 4K external EEPROM
- Power-On LED for indicator
- 20-Pin well marked Berg connector for ease of connection
- Access to all IO pins & supply pin on the Berg connector
- 20-Pin IC socket for MCU
- Four mounting holes of 3.2 mm each
- PCB dimensions 35 mm x 72 mm
AT89C2051 Development Stick – [Link]
I want do project under your lab
