![ATmega32U4-Based Synchronous MPPT Buck Solar Charger ATmega32U4-Based Synchronous MPPT Buck Solar Charger](https://www.electronics-lab.com/wp-content/uploads/2018/08/blob_il13KNkd4D.blob_.jpg)
You want to maximize the power output of your solar panel? Then you need a maximum power point tracking charge controller! Source files here.
Features:
- Programmable with Arduino IDE
- Input voltage: 15 – 22V
- Output voltage: 1 – 14.4V
- Simple MPPT (Maximum Power Point Tracking) solar charge controller for 18V solar panels
- Proper buck converter topology, which increases the current on the output side, not just PWM
- SparkFun Pro Micro 5V, 16MHz or 3.3V, 8MHz (3.3V recommended, more efficient)
- ACS712 current sensor (5A version) on the output side
- Voltage dividers for voltage measurement on panel and output side
- Two N-channel MOSFETs, driven by IR2104 half bridge driver, inductor (synchronous buck converter)
- Supplied by the panel voltage, so it can’t drain your battery during the night
- Working frequency 31.5kHz
- WARNING! This device is not intended to drive 5V USB devices directly. Do it at your own risk!
- Always use a regulated 5V USB adapter on the output! Otherwise, voltage glichtes may damage your USB device!
- This controller is COMMON NEGATIVE
- Three operation modes: MPPT, CV, CC
- SD card data logger for time, voltage and current. You can import the txt files in Excel
- WARNING! Always adjust output voltage and output current limits according to your battery type!!
- Efficiency between 84% and 92% (excluding board supply current of about 75mA)
ATmega32U4-Based Synchronous MPPT Buck Solar Charger – [Link]
Login
