![Automatic Light Switching System with Dimmer Automatic Light Switching System with Dimmer](https://www.electronics-lab.com/wp-content/uploads/2015/08/light_control.png)
Manual switching of outdoor lights in houses or roadways can be sometimes really inconvenient especially when we are far away or still at work. Sometimes this becomes an opportunity for thieves to infiltrate houses or a possibility of accident in roadways if night comes and our outdoor lights are still OFF. That is why the goal of this circuit is to automatically switch ON outdoor lights when it senses that it is getting dark and switch OFF lights when it’s daytime.
This type of light switching system is what we can usually see installed in streetlights or houses that are implementing automatic switching of outdoor lights. The system is not just limited to switching ON/OFF lights, it can also adjust the brightness of the lights so that it can just supply the right amount of luminance on the area required. This system is composed of a photocell, a receptacle, a ballast (with dimming control), and a lamp powered by the 220VAC mains. The photocell measures the light intensity level in an area and sends this data in a form of voltages (ranging from 0-10VDC) for the dimming control of the ballast. Based on the level of light intensity sensed by the photocell, the ballast will adjust the brightness of the lamp.
The whole system is supported by the TE Connectivity dimming receptacle 2213362-1. The photocell and ballast are connected through this receptacle. This dimming receptacle supports ANSI standard dimmable photocells with 5 positions (3 power contacts and 2 dimming signal contacts). Its power contacts can handle voltages up to 480V AC/DC provided that the maximum current passing through it will not exceed 15A. The dimming contacts of this receptacle supports 0-10VDC dimming method with a maximum current of 0.10A
Automatic Light Switching System with Dimmer – [Link]
