Avalue ESM-APLC – An Apollo Lake board that gives option for the Celeron®N3350 or Pentium®N4200 SoC
The Apollo Lake SoC has already be used in several boards and modules. Avalue, a technology company that has launched several single board products and with focus on innovative embedded products has recently launched an embedded platform called the “ESM-APLC“, a Linux-ready COM that provides support for either the Intel Apollo Lake Celeron®N3350 or Pentium®N4200 SoC.
Avalue ESM-APLC
Avalue which isn’t new to the Apolo Lake board designs released the EQM-APL last fall, a Qseven module based on the Intel’s Apollo Lake. The ESM-APLC module to some extent inherit some similar attributes of the EQM-APL module, just like the EQM-APL module allows one to use between the Apollo Atom, Celeron or the Pentium SoC, the ESM-APLC does the same with the major exemption of the Atom SoC. The ESM-APLC drops the Apollo Lake Atom SoC in its build.
The EQM-APLC module measures at 95 x 95mm in a Type6 style shape COM Express Compact module. It is equipped with the Intel Apollo lake Pentium N4200 1.1GHz  or Celeron N3350 1.1GHz  SoC Processors both of which have a low 6W TDP. ESM-APLC supports one 204-pin DDR3L 1866 SO-DIMM (up to 8GB via single socket), and the module supplies up to 64GB of optional onboard eMMC 5.0. Extensive I/O support including 8 x USB 2.0, 4 x USB 3.0, 2 x SATA III, 1 x UART, 1 x 8-bit GPIO, 1 x SMBus, 1 x LPC and 1 x I2C.
ESM-APLC provides a triple display interface option; it supports several graphics interfaces including dual-channel 18/24-bit LVDS with support up to 1920 x 1200 @60Hz, VGA Support up to 1920 x 1200 @60Hz, HDMI support up to 3840×2160 @30Hz and DP support 4096×2160 @60Hz. HD Audio is not left behind in this wealth of features.
The module expansion port comes with 3x PCIe GEN2 x1 interfaces and an optional 4 PCIe x1 or 1 PCIe x4 that comes at the cost of sacrificing the Ethernet. The module is expected to work optimally in 0 to 60°C operation with a wide range of temperature input (9- 19V AT/ATX input with ACPI 3.0. TPM 2.0 is optional). ESM-APLC is ideal for customers who need optimized processing and graphics performance with low power consumption in a long product life solution, such as embedded board, MID/UMPC, Microserver/Server and Consumer Electronics.
The module supports either Linux Kernel 4.5 and Windows® 10 Enterprise (64-bit). The module is available for purchase with no publicly disclosed price but can be obtained by contacting Avalue. More information about the product is available on the product page, and the datasheet can be downloaded here.
Hi, I'm software, a hardware guy, and a technical writer. Have had a stint with the EdTech industries, but mostly interested in the space of deploying AI for edge computing. Otherwise, I am writing or coding about some technology pieces covering IoT, GPU computing, LoraWAN, PCB, Machine Learning, Precision Agriculture, Open Electronics, and related fields. Got a tip, freebies, launch, gig or leak? Contact me on Twitter, or via email: charlesayibiowuAThotmail.com. I don't bite.
view all posts by ayo
