![Avnet Silica WiFi Shield based on AW-Cu300A module Avnet Silica WiFi Shield based on AW-Cu300A module](https://www.electronics-lab.com/wp-content/uploads/2019/06/avs-wifi-shield.jpg)
Based on AW-Cu300A module, providing Arduino pinout connectors.
Arduino Connector provides ultimate flexibility, leveraging on huge ecosystem of compatible boards, choose the microcontroller board that best fits your application and mix with sensors and other peripherals boards.
The board comes with Pmod connectors for extended compatibility with additional boards. The module is based on the 88MW300 WiFi SoC processor from Marvell and supports easy programming through commands send via UART interface. It can also be used as a processor board, where 88MW300 will implement the user application (SDK provided under NDA by Marvell). For single chip application, it provides full support for JTAG emulation.
- IO Interfaces
- UART
- JTAG
- GPIO
- SSP
- I2C
- GPT
- Internal Memory
- 2M Byte QSPI flash
- Wireless
- Wi-Fi 802.11 b/g/n
- Integrated Printed-Antenna / uFL connector
- High Integration and Low-BOM
- Single 3.3V Power Input
- Package
- LGA Module – 28 mm x 15 mm x 2.35 mm 74 pin
Login
