![BatteryProtect makes your Battery Smart BatteryProtect makes your Battery Smart](https://www.electronics-lab.com/wp-content/uploads/2019/02/Smart-BatteryProtect-48V-100A_91306429-690x559.png)
Prevent your battery from charging non-essential loads with BatteryProtect.
BatteryProtect is one of those smaller but much sought after products, one that is shipped in the many thousands. The latest version now has Victron ‘Smart’ tech. No more fiddling with wires to program, as the new Smart BatteryProtect uses VictronConnect over Bluetooth to simplify and reduce setup time. Smart BatteryProtect is used to disconnect a battery from non-essential loads before it is completely discharged (which would damage the battery) or before it has insufficient power left to crank an engine for example.
Product Range
Voltage and current ratings to suit the majority of applications:
- 12-24V 65A
- 12-24V 100A
- 12-24V 220A
- 48V 100A
![](https://www.electronics-lab.com/wp-content/uploads/2019/02/DS-smartBP220_91312006-690x299.jpg)
Key features
- Easy programming/setup using VictronConnect.
- Often used in lithium systems due to low standby current in comparison to a relay.
- Lithium system remotely controllable disconnect switch.
- Ideal for vehicles, solar installations, boats and motorhomes.
- Solid state switching for ignition proof safety and longevity.
- Lower energy consumption than closing a relay.
Mobile APP
![](https://www.electronics-lab.com/wp-content/uploads/2019/02/Smart-BatteryProtect-VictronConnect_92255682-690x604.png)
more information: www.victronenergy.com
Login
