![BD71631QWZ Battery Charger BD71631QWZ Battery Charger](https://www.electronics-lab.com/wp-content/uploads/2021/12/MFG_BD71631QWZ-TR-e1640361951270.png)
ROHM’s linear charger for low-voltage batteries achieves low-voltage charging over a wide range by improving the stability of the internal circuit
ROHM has developed a battery charger IC that supports low-voltage charging of not only lithium-ion but also all-solid and semi-solid state rechargeable batteries that use novel materials for the electrode part and batteries that adopt different terminal compositions. The BD71631QWZ achieves low-voltage charging over a wide range from 2.0 V to 4.7 V by improving the stability of the internal circuit.
- Compatible with all-solid/semi-solid state rechargeable batteries requiring low-voltage charging
- Package size optimized for applications equipped with thin rechargeable batteries
- Achieves optimal CCCV charging according to the characteristics of the rechargeable battery
more information: https://www.rohm.com/products/power-management/battery-management/battery-charge-management-ics/bd71631qwz-product
Login
