![BHI260AB Ultra-Low-Power Smart Sensor Hub BHI260AB Ultra-Low-Power Smart Sensor Hub](https://www.electronics-lab.com/wp-content/uploads/2020/06/BHI260AB_SPL.jpg)
Bosch Sensortec’s BHI260AB ultra-low-power high-performance smart sensor hub with integrated accelerometer and gyroscope
Bosch Sensortec’s BHI260AB is a family of ultra-low-power smart hubs consisting of Bosch Sensortech’s programmable 32-bit microcontroller (Fuser2), a state-of-the-art 6-axis IMU, and a powerful software framework containing pre-installed sensor fusion and other sensor processing software within a small 44-pad LGA package.
The Fuser2 Core is configurable to operate at 20 MHz (Long Run mode) and 50 MHz (Turbo mode). It can boot from a wide variety of hosts, ranging from a small Arm® Cortex®-M0 MCU up to multicore application processors, while it can also run standalone when booting from an attached Flash memory. In combination with its wide connectivity and extendability, the BHI260AB becomes a versatile and ideal solution when it comes to always-on sensor processing at ultra-low-power consumption.
Hardware Features
- CPU core
- ARC® EM4 CPU with ARCv2 16/32 bit instruction set (up to 3.6 CoreMark/MHz)
- Floating point unit (FPU) / memory protection unit (MPU)
- 4-channel micro DMA controller / 2-way associative cache controller
- Memory
- 256 kB on-chip SRAM
- 144 kB on-chip ROM preloaded with software
- Up to 8 MB external Flash for execute in place (XiP) code execution
- Connectivity
- Host interface configurable as SPI or I2C
- 3 master interfaces (selectable out of 2x SPI master and 2x I2C master)
- Up to 25 GPIOs
- Fast I/O operations
- SPI and GPIOS up to 50 MHz
- I2C up to 3.4 MHz
- Integrated sensor [six degrees of freedom inertial measurement unit (6-DoF IMU)]
- 16-bit 3-axis accelerometer
- 16-bit 3-axis gyroscope
Software Features
- Open sensor development platform
- Integrated software framework and OpenRTOS™ with full Android™ compliant sensor stack
- Integrated BSX sensor fusion software for reliable 3D motion tracking, activity recognition, and more
- Powerful SDK for easy customization and support for
- Metaware C Compiler for ARC
- GNU C Compiler for ARC
Applications
- 24/7 always-on sensor processing at ultra-low-power consumption
- 3D orientation, step counting, position tracking, activity recognition, pose and head tracking, and context awareness
- Wrist-mounted, hearables, eyewear, and other wearable devices
- Smartphones and other mobile communication devices
- AR/VR/MR headset and controller devices
more information: www.bosch-sensortec.com
