![Big digit 7-segment Clock using ATtiny3216 Big digit 7-segment Clock using ATtiny3216](https://www.electronics-lab.com/wp-content/uploads/2020/01/bigtimefront.jpg)
This is a giant digital clock, featuring four large LED displays that provide the time in a format you can read from the other side of the room. by David Johnson-Davies:
This clock was inspired by some 2.3″ one-digit 7-segment displays I saw on AliExpress [1]. I decided it would be fun to have a clock that you can see clearly from a distance. The displays come in a variety of colours and voltages; I chose the red 4V versions so I could drive them directly from the microcontroller’s I/O lines without needing driver transistors. My displays are common-cathode, but a minor change to the program would make it work with common-anode displays.
Big digit 7-segment Clock using ATtiny3216 – [Link]
Login
