![Bosch IXO 3 screwdriver offers high efficiency and performance Bosch IXO 3 screwdriver offers high efficiency and performance](https://www.electronics-lab.com/wp-content/uploads/2020/11/01055223-scaled-e1606843120123.jpg)
The Bosch IXO 3 is a cordless screwdriver from Bosch. Bosch is popular for its quality of brand and products they produce, and the Bosch IXO 3 doesn’t fall short of their high-quality product. Unboxing the Bosch IXO 3, which comes in a tin box packaging that is practical and beautiful, you find a cordless Li-Ion screwdriver, 10 standard screwdriver bits, 5 hrs charger base, and an instruction manual. The Bosch IXO 3 comes in a beautiful carry case that fits everything neatly inside.
Package Contents:
- 1x BOSCH IXO 3 Electric Screwdriver
- 1x Hexagon shank drill bit
- 1x Extension rod
- 1x Screwdriver head set
- 1x Charger
- 1x Tin box packaging
At the first squeeze of the trigger, the screwdriver might feel like it lacks power. However, when you put a screw to it, it drives it effortlessly into place. The Bosch IXO 3 helps decrease the amount of time it takes to remove and fasten screws, and it enables a reasonable speed that doesn’t damage components or strip screw heads. However, we should note that just like every other conventional electric screwdriver, you may not be able to use the Bosch IXO 3 to drive screws straight into the wood without creating pilot holes. For that purpose, you may use the drill bit provided in the box. They are primarily meant for assembly and disassembly.
Additionally, the Bosch IXO 3 features a LED light when in use. You have the option of spread lighting or spotlighting. The bright white LED enables you to see what you are working on with ease. It comes with a charging base with a mains cable and offers 5 hours of charging time. The length is only 14cm, which can be easily fit into the pocket, Only 0.3 kilograms, equivalent to the weight of 2 Apple mobile phones. Its small size makes it easy to operate even with slender hands. The Bosch IXO 3 is multipurpose. It enables an optional tilt screw and torque setting adapter for wider application. Even though of its’s small size, it offers high efficiency and performance. It also features a magnetic chuck, soft rubber grip design, forward and reverse switch, positive and negative indicator, and a Bosch lithium battery technology inside.
Specifications include:
- Maximum torque: 4/3Nm
- No-load rate: 180rpm/min
- Charging time: 5h
- Battery capacity: 3.6V/1.3Ah
- Weight incl. battery : 0.3kg
- Screw bits: PH1, PH2, PH3, PZ1, PZ2, PZ3, S4, S6, T20, T25
Once you register the Bosch IXO 3 online with Bosch, the standard two-year guarantee is extended to 3 years. The Bosch IXO 3 is one of the best cordless screwdrivers available in the market now.
You can get the Bosch IXO 3 on Banggood for $69.99
