![Bourns SRF7035A Common Mode Chokes Bourns SRF7035A Common Mode Chokes](https://www.electronics-lab.com/wp-content/uploads/2021/11/138544901.png)
Bourns SRF7035A Common Mode Chokes are AEC-Q200 compliant and offer an 80VDC rated voltage and -40°C to +125°C temperature range. These chokes feature a compact size and high impedance over a broad frequency range to suppress electromagnetic interference (EMI) coming into or leaving the system. SRF7035A chokes have shielded construction, separated winding, and a sector-wound configuration. Bourns SRF7035A Common Mode Chokes are ideal for use in DC/DC converters, switch-mode power supplies, and power system noise suppression in industrial, consumer, and other electronics.
- Shielded construction – low radiation
- Separated winding
- High current capability
- Compact design
- AEC-Q200 compliant
- RoHS compliant
- Halogen free
Specifications
- 4µH to 22.6µH inductance range
- 300Ω to 3000Ω impedance range at 1MHz
- 1.2A to 5A current range
- 80VDC rated voltage
- -40°C to +125°C temperature range
- 7mm x 6mm x 3.5mm dimensions
more information: https://www.bourns.com/docs/technical-documents/featured-product-bulletins/Bourns_IC2194_SRF7035A_NPR.pdf
Login
