![Broadcom ACHS-719x family hall effect current sensors Broadcom ACHS-719x family hall effect current sensors](https://www.electronics-lab.com/wp-content/uploads/2020/04/BroadcomACHS-719xFamily.jpg)
The ACHS-719x product series is a fully integrated Hall Effect-based isolated linear current sensor device family designed for AC or DC current sensing
The ACHS-719x product series is a fully integrated Hall Effect-based isolated linear current sensor device family designed for AC or DC current sensing in industrial, commercial, and communications systems. The family consists of products with a sensing current ranging from ±10 A to ±50 A. The devices offer a precise, low-offset, linear Hall circuit with a copper conduction path located near the surface of the die. Applied current generates a magnetic field that the Hall IC converts into a proportional voltage. Device accuracy is optimized through the use of differential Hall transducers.
Key features
- Wide Operating Temperature Range: from -40ºC to 110ºC
- Primary Conductor Resistance: 0.7 mΩ Typ.
- Sensing Current Ranges: ±10A, ±20A, ±30A, ±40A, and ±50A
- Output Sensitivity: from 40 to 185 mV/A
Additional features
- Low-resistance current conduction path
- Output voltage proportional to AC or DC currents
- Ratiometric output from supply voltage
- Single supply operation: 5.0 V
- Low noise analog signal path
- Device bandwidth is set via the filter pin:
- 80 kHz typ. with 1 nF filter capacitor
- Factory-trimmed for high accuracy
- Extremely stable output offset voltage
- Near-zero magnetic hysteresis
- Total output error:
- ≤ ±6% across the range from -40 to 110 °C
- >25 kV/µs common-mode transient immunity
- Small footprint, low profile SO-8 package
- Isolation voltage:
- 3kVRMS, 1 minute
- Worldwide safety:
- UL, CSA, IEC/EN 62368-1
more information: www.broadcom.com
