![Broadcom AUV3-Sxxx – UV-A LEDs surface mount UV LEDs Broadcom AUV3-Sxxx – UV-A LEDs surface mount UV LEDs](https://www.electronics-lab.com/wp-content/uploads/2020/12/BroadcomAUV3-Sxxx-UV-ALEDs.jpg)
The 3W 3535 Surface Mount UV LEDs are energy-efficient LEDs that can be driven using high currents and can dissipate heat efficiently
The 3W 3535 Surface Mount UV LEDs are energy-efficient LEDs that can be driven using high currents and can dissipate heat efficiently, resulting in higher reliability. Their low-profile package design addresses a wide variety of applications where superior robustness and high efficiency are required. They are packaged with ceramic-based materials, and the quartz lens on top of the package provides the product longevity needed for the respective end applications. To facilitate easy pick & place assembly, the LEDs are packed in tape and reel. Each reel is shipped in a single flux and single color bin to ensure close uniformity.
Key features
- High-reliability package with quartz encapsulation
- High-radiant flux output using InGaN dice technolog
- Available in 360-nm to 400-nm wavelength range
- Available in 35° and 60° viewing angles
Additional features
- Lens material: quartz
- Terminals finish: gold plated
- Electrically isolated thermal pad
- Manufacturing technology: InGaN
- Absolute max. power: 4000 mW (2800 mW for 360-nm devices)
- Absolute max. forward current: 1000 ma (700 mA for 360-nm devices)
- Dimensions: 3.5 x 3.5 mm
- Compatible with the reflow soldering process
- JEDEC MSL 1
more information: https://www.broadcom.com/products/leds-and-displays/ultraviolet-leds/auv3-sq62-0rt0k
