This project enables the user to control a Brushed DC Motor using an Infra-Red Remote Control, thus controlling speed, direction, and also brake of DC Motor is possible. It’s an Arduino compatible open-source hardware that helps you develop many DC Motor control applications. The user has to write the code as per the application requirement. The project is based on three main parts, Atmega328 microcontroller, LMD18201 DC Motor H-bridge, and TSOP1838 Infra-red receiver. This board can control DC motor up to 48V DC with continuous current up to 3A and with peak current 6A.
Example Arduino code is available under Downloads below. This code will help you to control the speed of the motor in 4 steps up/down using an infra-red remote control with help of two switches.
Brushed DC Motor Controller Using Infra-Red Remote – [Link]
