![Brushed DC Motor Speed and Direction Controller Using Joystick Brushed DC Motor Speed and Direction Controller Using Joystick](https://www.electronics-lab.com/wp-content/uploads/2020/11/004-e1604493366343.jpg)
This DC Motor controller provides direction and speed control of a brushed DC motor using a Joystick. This is an Arduino compatible open-source hardware with various applications. It can be used to control scissor lift motor, Linear actuator, Camera slider, camera pan-tilt head, curtain motor, power window motor, robotics, smart furniture automation, hospital furniture automation, projector up/down controller, TV up/down controller are few application examples. The board provides superb performance, smooth movement of motor, and hassle-free use. You only need to connect the motor wires, power the board, and you ready to go.
The controller has 3 main elements, Atmega328 Micro-Controller, LMD18201 DC Motor H-bridge, and Joystick connected to A0 Analog pin of microcontroller. This board can control DC motor up to 48V DC with continuous current up to 3A and peak current 6A.
Brushed DC Motor Speed and Direction Controller Using Joystick – [Link]
