Have you ever needed to power a project that’s not near an outlet? Have you needed to test using different voltages? Are you curious about analog circuits and power? Using Autodesk Circuits and a lead-acid battery, you can create a circuit that will act as a variable power supply, outputting a range of voltages from 5V to 20V.
Build an Arduino boost converter – [Link]
Login
