Building an extremely high powered 1-12V lab power supply on the cheap
Matthew Millman has published a new project:
For a number of years now I’ve had a couple of high powered switching power supply units made by Power-One. They’re typically found in I.T. equipment and provide a single output rail of either 12 V or 48 V with a very high current rating. The other cool thing is that in the case of the 12 V model – the output voltage can be changed in software from 1 V to 12 V (12.45 V is the max). The 48 V model does not allow configuration of the output voltage frustratingly.
Building an extremely high powered 1-12V lab power supply on the cheap – [Link]
Login
