Photodiode-with-Liquid-Rubber-Coating-1024×683.jpg - Electronics-Lab.com
101
Building a PIN Diode Geiger Counter
"Kai" is in the process of building a Geiger counter based on BPW34 photodiode and explains his first step for the sensor circuit. The common approach to protect the photodiodes from light is to use one layer of tin foil and connect it to ground. This should also protect the circuit against el... Read More
