Astable multivibrator calculator
This calculator helps you to compute the value of Output frequency, Capacitor, and Duty cycle in a 555 astable multivibrator.
This calculator needs at least three inputs to compute results. All the fields except the Duty Cycle can be used as input.
  • RA & RB: Input
  • C & F : Input/Output
  • D : Output
The resulting output from above calculator are approximate values. Refer to standard Resistor and Capacitor table to choose the right component for your design.
FORMULAS:
With given RA, RC and C values. Frequency and Duty cycle can be calculated using the below formula F = 1.44 / (( RA +2RB) C) D = ( RA + RB ) / ( RA + 2RB ) Using RA, RC and F values, Capacitance can be calculated using the below formula C = 1.44 / (( RA + 2RB ) F )
TOP PCB Companies
