Linear regulator power dissipation calculator
This calculator helps you to compute the power dissipated in a linear voltage regulator based on the input voltage, output voltage, and output load current. This calculator needs at least three inputs to compute results.
Definitions
- VIN & VOUT : Input,
- PD & IOUT : Input/Output
