Enter the input resistor and feedback resistor in the below op-amp calculators to calculate the voltage gain.
Working of Inverting Op-amp Gain Calculator
Inverting op-amp gain calculator calculates the gain of inverting op-amp according to the input resistor R
in and feedback resistor R
f. The gain indicates the factor by which the output voltage is amplified, i.e. it tells how many times the output voltage will be than the input voltage. The equation to calculate the gain is given below
Gain = Rf/Rin
For example if the gain is 5, then the output voltage will be 5 times greater than the input voltage.
Working of non-Inverting Op-amp Gain Calculator
This
non-inverting op-amp gain calculator calculates the gain for non-inverting op-amp according to the below equation, where R
in is the input resistor and R
f is the feedback resistor.
Gain = 1 + Rf/Rin
