Power Density Calculator
This Power density calculator allows you to measure the power density from an antenna to a certain distance, by providing the output power and gain values. Generally used in RF and Radar applications, power density is measure of the power in a certain distance from the antenna. Below is the formula to calculate the power density: Pd = Po*G/4*π*D2 Where: Pd = Power density in watts/m2 Po = Output power from the antenna in watts (W) G = Gain of the antenna D = Distance from the antenna in meters (m)
