Torque Calculator
Force Calculation
Distance Calculation
In physics, torque is the twisting force that causes the rotation. The point where the object rotates is called as pivot point or axis of rotation. If you apply a force at some distance from the pivot point, then even though this force will act along a straight line, the torque generated by this force will cause the object to rotate. You can use the above torque calculator to calculate the torque in a rotating object by providing force and distance values.
