![Calculate Size of Solar Panel, Battery Bank and Inverter (MS Excel Spreadsheet) Calculate Size of Solar Panel, Battery Bank and Inverter (MS Excel Spreadsheet)](https://www.electronics-lab.com/wp-content/uploads/2020/07/calculate-size-solar-panel-battery-bank-inverter.jpg)
Design of solar panel/battery bank and inverter using this Excel Sheet.
This MS Excel spreadsheet calculates the following:
- Total Demand Load
- Size of Solar Panel
- Select Type of Connection of Solar Panel
- Select Rating of Each Solar Panel
- Energy from Solar Panel as per Daily Sun lights
- Size Battery Bank
- Select Type of connection of Batteries in Battery Bank
- Size of Inverter
Calculate Size of Solar Panel, Battery Bank and Inverter (MS Excel Spreadsheet) – [XLS]
please share download link for your solar pv design software. i require it for an under graduate research project. thanks
I’ve updated the XLS link above, please check.
hi mike,
how have you implemented battery depth of discharge and solar efficiency. I am designing a similar project for school and cant get my head around how to implement these formulas using excel solver?
any help would be greatly appreciated
hey could you give me the password to unprotect sheet
There is no password to open the XLS file
We can’t add any load data 🙁
Hello We need a passport to add some load data. Could you provide it?
Could you check if there is any author contact info?
This sheet is gold. Thanks I am always looking for excel sheets that make my job easier.
Dear Author,
I dont see a link to download the file. Could you please provide it? Highly appreciated!
There is a link with name XLS just below the post.
