![CAPUF Embedded Industrial Grade Isolated USB to UART Converter: Secure, Reliable, and Versatile CAPUF Embedded Industrial Grade Isolated USB to UART Converter: Secure, Reliable, and Versatile](https://www.electronics-lab.com/wp-content/uploads/2024/04/Isolated-USB-to-UART-Converter-e1713985465797.webp)
Introducing the Industrial grade Isolated USB to UART Converter, a solution developed by CAPUF Embedded. This converter is essential in embedded systems, facilitating tasks like viewing debug messages, flashing programs, and configuring devices via command/response protocol.
The Industrial Grade Isolated USB to UART Converter is designed to meet diverse industry needs. It’s particularly useful in scenarios involving high-voltage AC/DC circuits, ensuring safe connections between high-voltage circuits and laptops or PCs, and protecting against potential damage or induced leakage currents.
This converter provides a reliable solution for low-power embedded designs requiring voltage levels as low as 2.5V or 1.8V. It caters to battery-powered devices like asset trackers and wearables, ensuring seamless connectivity while maintaining optimal voltage levels.
The isolated USB to UART converter shines in medical electronics and noise-sensitive circuits, where safety and noise reduction are critical concerns. It offers galvanic isolation to safeguard both power and I/O signals, providing a secure connection between embedded boards and external devices.
Key Specifications
- USB-C Port: Enables versatile connectivity options.
- USB to UART Bridge: Supports data rates of up to 3Mbps.
- Isolated Power: Capable of supplying up to 100mA and short-circuit protection.
- Isolated RX, TX, RTS, CTS, DTR, DSR, and all IOs: Ensures comprehensive protection against ESD.
- Signal Voltage Level Selection: Easily configurable via DIP switch (1.8V/2.5V/3.3V/5.0V).
- Power Selection Jumper: Allows for flexible powering options.
- LED Indication: Provides visual feedback for RX, TX, and Power status.
- Compact Size: Measuring 30.5mm x 70.5mm, it offers a space-efficient solution.
Block Diagram
With its robust design, versatile features, and exceptional performance, the Industrial Grade Isolated USB to UART Converter from CAPUF Embedded is the ideal choice for demanding industrial applications. Head to the product page if you want more information.
