![ChargEST, A Travel Adapter To Charge Your Devices ChargEST, A Travel Adapter To Charge Your Devices](https://www.electronics-lab.com/wp-content/uploads/2017/01/chargest1.png)
When you travel, it’s a bit frustrating to fill your luggage with lots of chargers, cables, and adapters to fit your charging needs. In addition to the space it takes which makes it harder to bring every kind of charger you may need.
ChargEST is designed to become your charging companion anywhere in the world you might be, so you can power up all your devices with a single accessory. It is compatible with USA, UK, Europe, Australia and 150 other outlet and plug standards, that charges cable-less up to two mobile devices with its fast-charging integrated pins and any other devices with the three USB ports.
The ChargEST is a small 8x8x4 cm portable device that fits in your pocket. It is built using high-quality materials and has three fast-charging USB ports, GoGreen on/off button, two height adjustable MicroUSB pins, and USB-C and Lightning plug extensions. You can charge up to six devices at the same time with 6.3A total charging power.
Safety comes as a top priority for ChargEST. Equipped with child-proof design and protection for overheating, short-circuit, voltage variation, and overcharging, you can be assured of having a safe charging experience every single time.
In addition to the ChargEST adapter, there are another two versions: ChargEST Bank, and ChargEST Double. The Bank provides you with extra 6300mA battery for your ChargEST to stay charged wherever you are on the go. It can fully-charge your iPhone or Android smartphone up to 3 times and also has an additional USB outlet to charge any other device.
ChargEST Double is the same of the original ChargEST but with an extra socket to connect other devices.
Six days left for the Indiegogo campaign with a goal of $20,000. However, they raised around $200k till now.
Have you heard anything from them recently? The project seems to have halted, they haven’t posted any update for two months now.
