![CircuitBrains boards, castellated modules coming soon … CircuitBrains boards, castellated modules coming soon …](https://www.electronics-lab.com/wp-content/uploads/2020/02/21820circuitbrains_basic.jpg)
Kevin’s CircuitBrains boards are now listed and live on circuitpython.org/downloads. Kevin submitted the Deluxe model to Crowd Supply will have a project to support fabrication and fulfillment soon – Twitter. [via]
CircuitBrains Basic
CircuitPython on an ARM Cortex M0 in 1 square inch! This “Just Add Solder” castellated module is perfect for incorporating into your own project. The CircuitBrains Basic board footprint is small enough to fit into narrow spaces and wearable projects.
Technical Specs
- Dimensions: 25 x 25 x 3.5 millimeters / 1 x 1 x 0.15 inches
- Atmel ATSAMD21E18 Microcontroller (32-bit ARM Cortex M0)
- 48 MHz
- 32 KB SRAM
- 256 KB Flash
- 4 MB QSPI Flash
- Onboard 3.3V LDO Regulator
- Power and Status LEDs
- Breakouts for SPI and I2C
- Breakouts for 4 Analog and 8 Digital Inputs/Outputs
CircuitBrains Deluxe
CircuitPython on an ARM Cortex M4 in almost 1 square inch! This “Just Add Solder” castellated module is perfect for incorporating into your own project. The CircuitBrains Deluxe board footprint is small enough to fit into narrow spaces and wearable projects.
Technical Specs
- Dimensions: 29 x 29 x 3.5 millimeters / 1.15 x 1.15 x 0.15 inches
- Atmel ATSAMD51J19A Microcontroller (32-bit ARM Cortex M4)
- 120 MHz
- 192 KB SRAM
- 512 KB Flash
- 8 MB QSPI Flash
- Breakouts for 14 Analog and 19 Digital Inputs/Outputs
Purchase
Coming soon. Follow the below links for manufacturing updates:
