Clinical-grade human body temperature sensor has ±0.1°C accuracy
5.852
Views0 Comments
Maxim Integrated has posted details of the MAX30205 temperature sensor for thermometer applications. The sensor accurately measures temperature and provide an overtemperature alarm/interrupt/shutdown output. by Graham Prophet @ edn.com
The chip converts the temperature measurements to digital form using a high-resolution, sigma-delta, ADC. Accuracy meets clinical thermometry specification of the ASTM E1112 when soldered on the final PCB. Communication is through an I ²C-compatible 2-wire serial interface that accepts standard write byte, read byte, send byte, and receive byte commands to read the temperature data and configure the behaviour of the open-drain overtemperature shutdown output.
Clinical-grade human body temperature sensor has ±0.1°C accuracy – [Link]
When you login first time using a Social Login button, we collect your account public profile information shared by Social Login provider, based on your privacy settings. We also get your email address to automatically create an account for you in our website. Once your account is created, you'll be logged-in to this account.
DisagreeAgree
Connect with
I allow to create an account
